-   -   Ice backlight kits (https://www.rctech.net/forum/radio-electronics/218865-ice-backlight-kits.html)
iluvmud 04-25-2008 10:47 AM
Ice backlight kits
... are they even around anymore??
Ive looked around but cant find any..... i tried to email HobiKit....... but of course no reply..... if anyone knows where to find one please let me know..
Thanks MUD
rezenclowd3 04-25-2008 01:06 PM
Look here: Caribbean Custom Designs
iluvmud 04-25-2008 02:35 PM
man was getting excited then saw they dont have any :-(
quick5pnt0 04-25-2008 07:30 PM
http://cgi.ebay.com/Backlight-Upgrad...QQcmdZViewItem
iluvmud 04-25-2008 07:45 PM
some SOB bought it while i was tryin to pay for it!!!!!!!!!!!!!!!
Clippy 04-26-2008 06:03 AM
Just a quick heads up,
Mine lasted 9 months then the inverter went up in smoke while I was charging. Lucky I was there and killed the power. I thought my charger was toast until I pulled it apart and found the inverter for the backlight had cooked itself and melted the heatshrink. I just cut it out of the charger and now it's back to normal. Be careful with it ;)
quick5pnt0 04-26-2008 12:44 PM
Just email the seller, he looks to sell a lot of those so I'm certain he'll have more.
FOXY923 04-26-2008 04:29 PM
A switch installed to cut the power when the screen is not in use will help to increase the life of your backlight;)
air8 04-27-2008 02:09 AM
Hmmm....I should have thought of that when I put mine in. Doh!!
iluvmud 04-27-2008 09:59 AM
ROFL i did that..... he said theyre on backorder!!!!!:flaming::flaming::flaming::flaming:
and thats a really go idea on making the switch for it.........
i have an off topic ?? now, i have two ice chargers, can one power supply run them both or do i need a separate on for each, this is the power supply i have.... http://competitionelectronics.com/pages/pwr_supply.html
Dave H 04-27-2008 12:23 PM
Depends on what ya charging. I run 2 ICEs charging standard 1/10 scale stuff, 7.2 volt nimh and 7.4 2s lipos, at 5 to 6 amps each, with a 20 amp supply with no problems.
But if you're charging 4s lipos at 8 amps each, then no. The ICE manual says it needs a max of 15 amps. And I would not recommend running any power supply, rc or otherwise, at max rating, suggest a little safety factor for long reliable life.
iluvmud 04-27-2008 12:50 PM
Ok thanks, i havent gont about 3amps......i think most i would do is around 6 if even that high..... so it looks like i can.... THANKS MUD
quick5pnt0 04-27-2008 02:10 PM
You've got a PM.
iluvmud 04-28-2008 12:31 PM
got it man thanks....... now i gotta get my desk setup for two..... :)
