3 time used LRP TC SPEC, just dies
Got a brand new TC SPEC from LRP to my FT T4 truck.. 1st time indoor it was working ACE..a few weeks later it begins to die (almost like failsafe or cutoff) but the fan still rotating, and sometime it stops..meaning no power or so..
havnt used the truck for a few month so it was a test day yesteday, and there it was again, only a 1/2 lap then it started... ive tried everythin, new cap,cap on Spectrum Rx (never ever had to use on my other cars, but i wanted to test it) i have solder a new Rx cable from ESC, new on/off button..still no good, can trottle a few tiimes full on ground, then it dies.. anyt tip what this can be?
i almost gave this ESC up, and a resend it to LRP is no option...
Myself and at least one other bloke at my local track also had problems. Apparently his ended up being a dodgy sensor harness from the motor -> ESC. As these speedies are sensor based they won't run without it. My car would go again if I gave it a push when it happened. I ended up just double checking the harness was plugged in properly then just used the plastic "tool" that comes with the ESC to push each individual pin in on motor and ESC. I use 7.5, 6.5 and 5.5 vectors depending on track and it seems to be fine now regardless of which sensor harness I use (they all have one )
Try checking that and see how it goes.
Cheers,
Clint.
Cheers,
Clint.
thanx clippy,tried that one to ..if ya disconct the sensorcable the ESC still work,but motor are "glitching"...bt my dies, i mean no powa at all to the ESC, just when i touch the cables, or + - or so, or just knock ,the ESC start up a gain...
Have you double checked all of the solder joints? I've seen this come up with every brand on these threads, seems to be the fix some times. For both suspected BL speedos and motors.
