-   -   Nomadio Sensor channel 4 (https://www.rctech.net/forum/radio-electronics/214878-nomadio-sensor-channel-4-a.html)
losi_alaska 03-31-2008 01:53 PM
Can some one please help me step up my sensor for my crawler, I would like 4 wheel steer, I also would like to have it be independent with a push of a button, I would like to use the thumb wheel for 4 ws. I need step by step instructions for dummies like me:weird::confused: every time I try to set it up from my putor, something else isn't right
thanks
vtl1180ny 04-05-2008 06:44 PM
It's really very simple, I use the 4th channel for an ignition kill switch on my 5th scale. If you are running a receiver battery you're going to have to use a Y cable, the servo in one end and the battery in the other.
Chose which button or switch you want to use for the steering and assign it to channel 4. You'll probably have to play around with the settings and steps to get it to where you want it to be...
