How Much Amps Should a Power Supply Have? >
Old 03-22-2008, 06:33 AM
Boosted561's Avatar
Default How Much Amps Should a Power Supply Have?
I'm just getting back in the hobby. so for now. The only thing I need the power supply to do is power a charger. In the future I may need it to power a few other devices. What's the amperage I should be looking for?
Boosted561 is offline
Old 03-22-2008, 07:33 AM
Figure out the current draw you plan to use and add 25% to it for safety.
Most get by with a 20AMP supply.
AreCee is offline
Old 03-22-2008, 07:48 AM
CREWMAN's Avatar
Trader Rating: 19 (100%+)
yea 20 amps is a good place to start and then you can build from there. if you are on a budjet and you only need to run a charger go smaller.
i am bored so i will leave examples
http://www3.towerhobbies.com/cgi-bin...?&I=LXLGF3&P=7
this one is only 14amps but it would do the job.
this is the one i would get
http://www3.towerhobbies.com/cgi-bin...?&I=LXTYY3&P=7
CREWMAN is offline
Old 03-22-2008, 08:08 AM
Boosted561's Avatar
Thanks Crew! I'll add it to my shopping list.
Old 03-22-2008, 08:30 PM
air8's Avatar
http://www3.towerhobbies.com/cgi-bin...&I=LXRJN7&P=ML
If you just want to get started this one works good. I have been using it for about 6 months now. I run two ICE chargers that charge at 6amps and a 4" cooling fan. But of course the chargers aren't pulling six amps. They only pull about 3.5amps. Anyways. Works very well.
air8 is offline
Old 03-22-2008, 10:55 PM
OFNA 18AMP PS @ $99.95 is a good PS. Light, small and can adjust voltage also comes with a buss.
AreCee is offline
Old 03-23-2008, 01:28 AM
scrawl's Avatar
Another option is to build it yourself out of an computer power supply.
I too recently returned to the hobby and built one from an old 30amp PSU from a retired PC. Cost me about $10 in parts to complete. Plenty of instructions available online if you google "ATX lab power supply".
Its been happily running two chargers, discharger fans and a Smart Tray with no problems.
Details of mine are available here.
scrawl is offline
