-   -   what does "C" in lipo means.. (https://www.rctech.net/forum/radio-electronics/211538-what-does-c-lipo-means.html)
BapeSta 03-11-2008 12:39 AM
could someone help me about this.. i have a orion platinum edtion.. is this batt good? how could i know if the batts im gonna buy is "punchy" thanks..
Dave H 03-11-2008 03:22 AM
First off, Orions have a very good quality reputation, lots of fast guys use them, so yeah, it's a good battery.
The C value is a good indication of the ability to deliver punch. Basically C is the current that it takes to discharge in 1 hour. So in your case the 1C rate for your 4800mah battery is 4800ma, or 4.8 amps. I think your battery is rated at 15C, meaning it can deliver 72 amps continuously. Which is quite a lot, it can go above that for short punches. As another example, the Orion 3600 is rated at 25C, meaning it can do a little better in terms of punch, 90 amps. But since it's a smaller capacity/runtime, it will lose voltage a little quicker than the 4800, so they are probably fairly even in typical electric heats.
BapeSta 03-11-2008 04:02 AM
thanks so much.. i think imma go with platinum and carbon spec.. coz i do drifting and i run brushless motor.. thank you so much...:nod::D
Sabin 03-14-2008 04:37 PM
C stands for Columb, which is the amount of electrical energy passing a certain point per second.
It's also come to be known as a discharge rating.
Dave H 03-14-2008 08:21 PM
Sabin, the use of the letter C for battery rating really is coincidental to it's use to represent Columbs. What you say is correct, but a different subject. Just close enough to be confusing thou!
