-   -   Please help!. (https://www.rctech.net/forum/radio-electronics/211192-please-help.html)
jasono 03-09-2008 12:35 PM
Please help!.
Ive got a TT-01D chassis mazda rx 7, and ive got all the items you need like receiver transmitter etc. ive got everything in the right place but my teu 101 bk e.s.c keeps flashing red when i turn on the car. Ive tried to set it to my transmitter but it dosent work. please reply with help. thanks.
f1larry 03-19-2010 07:55 PM
never mind
minimadman2003 03-19-2010 08:17 PM
Still got a problem? Is the ESC beeping as it flashes? If so, that indicates no TX signal detected. Make sure your TX batteries are fresh and the transmitter is ON (LED, display, etc). Loose batteries are a problem with many RTR radios. If that's not the problem, you may have a bad TX or RX crystal. Does your radio work with 4-AA's or on a different car?
One last thing about the TEU 101, you MUST plug the battery plug into the RX as well as the signal plug. I don't recall what it does if you do not plug that one it, but it is also a common setup problem with that ESC.
