Servo Rebuild Question
I am replacing the case on my servo. Everything looks self explanatory except I have two small o'rings in the kit.
My only thought is that they are to be put in between the top plastic housing and the brass cupped insert to hold the gear stays. Unfortunately I am unable to pull the existing brass fitting out of the old servo top to see if there is indeed a small o'ring. |
| All times are GMT -7. It is currently 10:29 AM. |
