-   -   lipo charging (https://www.rctech.net/forum/radio-electronics/206950-lipo-charging.html)
chad220 02-20-2008 10:14 AM
lipo charging
I have finally decided its time to switch over to lipo, time has come to build new packs and i just dont want to deal with nimh again this season. However i have learned hardly nothing about lipos. I have some orion 3600's on the way now i just need a charger. I will need a lipo only charger, alot of them that i see are real cheap so i am unsure if they are good. I am unsure of what amps to charge at, what charge times will be like ect. if any one could clear some of this up for me that would be great. thanks.
novaracr70 02-20-2008 10:25 AM
3600 will charge at 3.6 amps. i use the orion avionics charger i love the ease of use and its priced well.
GSPOT 02-20-2008 10:30 AM
MULTIPLEX CHARGER IS THE WAY TO GO, ALL YOU DO IS SET THE VOLTS AND AMPS AND HIT START!
(ITS SMALL AND DOES EVERYTHING)
IT DOES NEED A 12V SOURCE THOUGH
GSPOT 02-20-2008 10:33 AM
http://www.ehobbies.com/mpu92531.html
HELL I HAVE 2!
HOPE THAT HELPS
