Power Master 2
Does anybody know how to hook up the much more power master 2 the 24amp one to the mains i am in the uk and am using 3 pin type adaptor plugs but the charger has the two pin type like on shavers. I wonder if anybody from the uk could help me on this one????and tell me how they use theirs, i have tryed using a converter adaptor if thats anything like the right name for it??? where you plug in the power master into a plug which has three pins on the other side but the power master is running too much power through it so the fuse just blows i would change the fuse but they only go up to 13a over so.....i just left that one the only thing i could think of was to cut the two pin type adaptor off and replace it with a three re-wiring everything when doing it but i have no idea of how to do this can someone please help because i am truely confused:confused:
thanks in advance mike:) |
| All times are GMT -7. It is currently 09:29 AM. |
