-   -   Older ESC question. (https://www.rctech.net/forum/radio-electronics/200187-older-esc-question.html)
Andy Haynes 01-11-2008 12:31 PM
Older ESC question.
Ok guys I am so outta date its not even funny. I am thinking of going with a Lipo set up but I am curious as to if the ESC I have is ok to run LIPO with. It is an older novak cyclone. The one with the one push button setting device. I was thinking of getting one of the 3200 carbon lipo's since they are fairly cheap now. I am just wondering if there is any reason I wouldn't be able to use this battery?
minicooper 01-11-2008 12:59 PM
Good to go. I am using an Atom from novak :nod:
When your car slows down stop and recharge
RCGaryK 01-11-2008 01:02 PM
You can also add on a Novak LiPo cutoff too just to make sure you don[t over-discharge it.
Andy Haynes 01-11-2008 01:30 PM
Ok good deal. I will solder up some new wires and roll out. I guess the other ? is what is the best lipo charger for the money? I no longer have a power supply so I would need one that is all inclusive. I saw one made by hyperion a 6 series. Is there one better?
jheimb4897 01-16-2008 01:54 AM
Hell yeah! Cyclone and Atom all the way! I still used them up until a year ago. I switched to the KO Propo VFS-1 series and now own 4 of them. Never going back. Let's hope KO comes out with BL, then maybe I'll think of switching... :ha:
But really, you can use it, just get a voltage cut-off from Novak or Futaba. $20 worth of insurance for your $120 batteries. Not a bad trade off I may say... ;)
tc3team 01-16-2008 08:43 AM
+1, I would rather add one of these than risk a lipo going flat... Its not worth it.
Jason Pelletier 01-16-2008 11:42 AM
Hyperion is good as long as you dont plan to ever discharge anything or charge your nimh/nicd batterys any higher then 5 amps.
Otherwise get a duratrax ice or pulsar 3 if you still have brushed motors and nimh /nicd battery's
Orion/Peak lipos dont need balancing but you can if you wanna.
Dealer Xing 12-25-2020 05:01 AM
Can Novak Atom handle 2s LiPo? The stock specs indicate 4-6 cells but I'd like to know if anyone uses 2s LiPo without blowing it up. Thanks
Juglenaut 12-26-2020 07:21 PM
Maximum electromotive force per cell ni-cd is 1.3vdc.
By theory the Atom esc technically needs to handle 7.8-8.0vdc.
Not sure a on NiMh with the atom, never tested that on a atom thou pushed the limits on my tempest
