Hitec Linx 3D.... Help!
I have come accross a Hitec Linx 3D radio with spectrum module. Could some one tell me what receivers work with this? Is the radio any good or is it too outdated? I have a spectrum DX3 but would like more model memory and this one is cheapish.
Terry |
Depends on spektrum sender module what recievers are working with this. By my understanding all recievers that are working with DX3 are working with modules to. More info from Spekrtum RC surface items home
I am using Lynx3D and quite happy with it, recently switched to spektrum sender modules and spektrum recievers, no problems so far.;) |
Since you misspelled Lynx, I'm wondering if you misspelled Spectra too. This is important because there are two completely different modules that work with the Lynx.
Spectra is Hitec's synthesized module that is 75MHz FM and will work with any negative shift reciever which has the appropriate crystal or synthesis. (Hitec or Futaba). Spektrum makes the 2.4GHz DSM module and will work with any Spektrum receiver except the one for Futaba HRS. |
| All times are GMT -7. It is currently 11:18 PM. |
