-   -   GTB drag brake issues... (https://www.rctech.net/forum/radio-electronics/193976-gtb-drag-brake-issues.html)
speedsterblade 12-03-2007 11:42 AM
anyone have problems setting the drag brake? I recently moved my gtb from my T4 to my TC4, redid the onetouch setup for different motor, all normal.....brushless rules btw!... I quickly found I needed some drag brake for the TC. I'm using the default profile (1#), go through the instructions for setting drag... Default was 3, I went up to 6 and saved it....yet out on the track nothing... No drag at all. Zero. Went through the programming again, I know the 6 took cause that is what I saw on the second attempted... 6 flashes. Bumped it up to 7, it saved.. yet still no drag at all...
Am I the only one have this issue? I've had this gtb just cut off on me before 2-3 times for like 2 or 3 seconds then it's fine...not sure why it did that but maybe related and I just got a pos? This is the newer one w/ lipo cutoff. My other gtb is older, no lip cutoff and it's been flawless but I've never changed anything from the stock profile.
Thanks.
Turbo Joe 12-03-2007 12:04 PM
1) blue and yellow are on, right?
2) Check your transmitter. It only makes drag brake when it gets a good neutral signal, so if you have your trims off, it won't do it. I have an old M8 and sometimes mine does that, too...so I just give it a tick or two of rear trim to put it towards brake just a touch.
speedsterblade 12-03-2007 12:56 PM
1) Yep.
2), you may be right. I got a new to me but old radio and have most settings at 0/centered.
Thanks!
chazman 12-04-2007 03:02 PM
i have a similar problem with my gtb i went to a meet and had the drag brakes set then after the first race i had no drag brakes what so ever and from then on it will loss drag breaks when it wants to,if u lose them all of a sudden then your gonna be sayin hi to the wall at my club:cry:
but still bl rocks
but
bl + demon 5000 lipo rules:nod:
Bull_Dog 12-04-2007 03:09 PM
Not sure if this will help but you may want to try profile 4 on the GTB I think that adds more drag brake from 20% to 40%
chazman 12-05-2007 03:05 PM
I have always been on profile number 4 thats the problem lol:cry:
has any1 else had the fan blade fly of whole or am I a world first:lol:
speedsterblade 12-10-2007 07:51 PM
Radio adjustment was the fix. I need to tweak a little more on the radio and/or the drag brake, it's on 7 and I need a touch more.
Here's a link to novaks troubleshooting:
http://www.teamnovak.com/tech_info/t...h.htm#tsg_OT_3
Turbo Joe 12-10-2007 08:29 PM
I think you're the 10,000th person...LOL The stock fans are pretty wimpy. :)
