KO PROPO.PDS-2367 with problem...
Hi guys!i have a PDS-2367 servo with 4 litre use in a rrr.yesterday i notice that it has not good centered when the tyres are on the ground.also it has a 20 degree range of slop..actually it's not a slop,it's like the center point is swifting in 20 degrees right or left,after these degrees the servo is starting to resist to the movement...i check the gears and everything is perfect!:confused:
Originally Posted by GREGORY!
(Post 3923464)
EDIT
NO.I have check it..is doing this and when i move the servo horn...
Check the insert that is inside the final gear of the servo (covered by bearing). If the insert is damaged, then the indexing for the pot will be off and not center correctly.
| All times are GMT -7. It is currently 05:14 AM. |
