Need Reviews: Muchmore Drive ESC >
Old 11-15-2007, 10:24 PM
Airflow's Avatar
Default Need Reviews: Muchmore Drive ESC
Anyone?
Airflow is offline
Old 11-16-2007, 04:21 AM
sosidge's Avatar
I can't give you an in depth review but having fitted and installed one in a 19T powered car that I tested briefly it seems to be a decent unit for the price, no setup issues and relatively compact.
sosidge is offline
Old 11-18-2007, 01:40 AM
Airflow's Avatar
Thats the reason I wanted that ESC--- the compact size (and waterproof). However, Ill be matching it a spektrum dx2 and Im worried that it might not supply enough current for the BEC which might cause trouble.
Another thing... can the reverse function be deactivated for races?
Airflow is offline
Old 11-19-2007, 04:17 AM
sosidge's Avatar
Unfortunately I do not have the technical specs with me so cannot answer your questions fully.
Can I suggest that you contact your local Much-More distributor directly? They should have access to the manual.
I have seen the ESC used with Spektrum, without problems (it was being used as a temporary replacement for a Hara speedo which DID have problems!), but I do not know about reverse lockout.
sosidge is offline
Old 11-20-2007, 04:00 AM
Airflow's Avatar
Thanks dude.
Our LHS owner doesnt know if it has reverse lockout since he doesnt want to open the sealed box. Im contemplating on getting that or the MC330CR for my TA05 im setting up.
Airflow is offline
