What is a Lipo Battery & Pro's&Con's Compared to Nimh?? >
Old 10-17-2007, 02:53 AM
Default What is a Lipo Battery & Pro's&Con's Compared to Nimh??
just watched RCTVLive and im not really clear on what Lipo's are and what the advantages are, comparing them to Nimah..
anyone that is in the Know HELP
DirtRacer is offline
Old 10-17-2007, 08:22 AM
KThatcher's Avatar
Trader Rating: 64 (100%+)
using them for what???? reciver, transmitter, electric rc car of truck??? I can tell you that i run a 7.4 volt 1500 mah in my truggy for the reciever, and the advatage is longer run times and not servo sag.. with the regulator it just cuts of power when the batt gets low...
KThatcher is offline
Old 10-17-2007, 08:43 AM
rampal's Avatar
In general lines, LiPos are lighter (for the same capacity) and maintain a more flat discharge curve versus time. Lipos don't peak, so if you're looking for punch like on electric racing, you won't find that out.... but you will certainly find longer run times.
in summary you can find on the pros:
+ lighter for the same capacity
+ longer run time
+ very low self-discharge rate
+ very flat discharge curve
in the cons:
- you need an special charger (CC/CV type)
- special care should be taken, as any battery chemistry (just a reminder)
- fragile (care should be taken to avoid punctures and physical damage)
- the battery don't peak, thus there is no high voltages waiting for you....
- they burn, don't explode... but again, which one is better?
hope that helps as a summary... anyway, there are several threads on this subject on rcgroups or here on electric on-road, do a search around.
rampal is offline
Old 10-17-2007, 04:45 PM
alright then, yea thanks for the info "Rampal"
