Checkpoint Charger Questions >
Old 10-14-2007, 11:09 AM
Jeel's Avatar
Trader Rating: 16 (100%+)
Default Checkpoint Charger Questions
Is the motor run in feature powerful enough to run a lathe off of? (My ICE never could but my GFX never had a problem)
Can this charger handle it's 30 pulse discharge? I have heard grumblings of it going up in smoke if discharged at 30amps?
Thanks for the HONEST feedback.
Jeel is offline
Old 10-14-2007, 11:13 AM
Regional Moderator
CarbonJoe's Avatar
What motor are you using on your lathe? I have no problem powering my Cobra lathe using an Integy 55T lathe motor on my ICE. I never go above 3-4 volts, and it has never given me any issues?
CarbonJoe is offline
Old 10-14-2007, 09:12 PM
mojoman's Avatar
I've gone through my third charger repair the latest incident was tonight. I simply put a half charged pack into the charger and at the end of it's discharge cycle it went poof!! For the third time. Hobbico has repaired the last two. This time it's a new charger or my cash back. I'm sick of waiting for the mail. Sorry had to vent.
Peace,
C
mojoman is offline
Old 10-15-2007, 09:22 AM
James35's Avatar
You should have much better luck running your lathe off of the Team Checkpoint charger as they doubled the amperage. The motor break-in feature on the ICE would quit if the motor/lathe pulled over 10 amps. The Checkpoint charger supplies up to 20 amps to your motor/lathe.
James35 is offline
