ORION AVIONICS CHARGER
Old 10-08-2007, 04:51 PM
pink_sleeve's Avatar
Trader Rating: 170 (99%+)
Default ORION AVIONICS CHARGER
does this charger store charge settings for different packs
pink_sleeve is offline
Old 10-08-2007, 06:58 PM
kuzo's Avatar
If you mean this one:
http://www2.towerhobbies.com/cgi-bin...&I=LXMRH8&P=ML
No it doesn't. Just remembers last setting used. Quick to change though.
kuzo is offline
Old 10-08-2007, 07:06 PM
so if you charge a reciever pack then a 4800 then a 3200 you have to change all the settings each time
Old 10-08-2007, 07:10 PM
kuzo's Avatar
Yes, at least the pack capacity in your example. You aren't changing battery type just charge rate.
kuzo is offline
Old 10-08-2007, 07:22 PM
do you have to change only the 3200 4800 or whatever the lipo is since they are all 7.4. and does it set the charge rate at 4.8 for the 4800 or do you program it to that
Old 10-08-2007, 10:01 PM
more$thanbrains's Avatar
no need to change capacity numbers just amperage numbers
more$thanbrains is offline
Old 10-08-2007, 11:02 PM
magm20001's Avatar
u dont set capacity.
magm20001 is offline
Old 10-08-2007, 11:49 PM
me?
i never do
hurts performance to hult charging halfway thru on NIMH packs
matt
Old 10-14-2007, 09:12 AM
what is the max amp rating it can charge lipo at. my 3200 take along time since my charger only goes to 2.5. i want to get agood size max amp battery but a 8000 will take to long to charge at 2.5 amp.
Jaysun is offline
Old 10-14-2007, 09:25 AM
Mr. Shookie's Avatar
I love my Orion Avionics Charger, but for larger capacity lipo's the Checkpoint can handle up to 10amps max charge rate for lipo's.
Hope that helps,
-Shookie <><
Mr. Shookie is offline
