Icharger Duo 4010 encoder wheel replacement?
The encoder wheel is starting to fail on my Icharger Duo 4010. This is the click wheel in the middle of the charger you rotate and push to select menu items. Mine will randomly select items when turned.
My unit is nearly 12 years old, so I opened up the case, and the encoder looks a lot like this one: https://www.mouser.com/ProductDetail...252BmQUg%3D%3D Has anyone replaced their encoder switch, and can tell me the part number of the switch they used? It's through-hole mounted, so I'm pretty sure I can pull the old one off the board without destroying the board. |
| All times are GMT -7. It is currently 05:14 AM. |
