Trx4 steering and throttle issues
I have a trx4 Bronco and the steering signal seems to be interfered with when I throttle forward. It works fine when no throttle is applied, but as soon as I touch the throttle the servo gets sluggish and slows down and is less powerful, and takes a second or two after releasing throttle to snap back to normal. In reverse it still works fine. Very confusing issue. Servo is confirmed by outside system to function normally, and the esc seems to be ok too, as I can drive normally except for the sluggish steering in forward. Very confusing. Any help would be appreciated.
