Wanting to convert server power supply >
Like Tree1Likes
  • 1 Post By BigRed
Old 06-06-2024, 06:33 AM
BigRed's Avatar
Trader Rating: 23 (100%+)
Default Wanting to convert server power supply
Looking for some help on converting a HP DPS-750AB-3 into a power supply. I haven't found anything specific to the model power supply. From what I've seen with other HP DPS models, bridging pin 33 and 36 will get the power supply to turn on.
BigRed is offline
Old 06-06-2024, 02:46 PM
gigaplex's Avatar
Have... You tried bridging those pins?
gigaplex is offline
Old 06-06-2024, 03:48 PM
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
I'm reasonably confident that's a "common slot" model. I built an adapter board and use a switch across 33 & 36 in series with a 100ohm resistor to turn it on/off. The ones I've built are using the 1200W version.
PDR is offline
Old 06-06-2024, 04:18 PM
BigRed's Avatar
Yes, the house burnt down ...
Just kidding, I gave it a go. The power supply turned on putting out 12.33v.
gigaplex likes this.
BigRed is offline
Old 06-06-2024, 04:23 PM
BigRed's Avatar
I happen to have this lying around from the crypto morning days and thought I might put it to use. I'd love to find shrink wrap or a custom skin for this thing.
BigRed is offline
Old 06-07-2024, 06:28 PM
Trader Rating: 33 (97%+)
check the pin out here, should be the same:
billdelong is offline
Old 06-08-2024, 09:02 AM
Geezatec's Avatar
Look up DPS-750AB-3A Manual online. Manuallib.com. Although it show 650AB it probably the same. 5V and 12V jumpers. What are you going to use it on?
Geezatec is offline
