-   -   BR1 Servo (https://www.rctech.net/forum/radio-electronics/1124248-br1-servo.html)
Themechanic 06-02-2024 02:07 AM
BR1 Servo
So the T4 I bought to get back into racing came fitted with a Bruno servo
A BR1-T4 WC v1 to be exact.
I’ve tried searching on the site but can’t find much info on the servo.
The site lists the servo as having a Bec voltage and speed at 6.0v. Can I set this higher?
Also I’m running it with a NB4 Pro, it says it’s digital but nothing mentioned about optimal frequency/hz.
Any info or advice here would be appreciated.
Or do I just get a power hd s15
savoxandy 06-17-2024 05:22 PM
this is 6V servo, but if you use LiFe bettery, you could use in 6.6v , the frequecy 333hz
i believe this is the best servo for T4
Roelof 06-18-2024 01:25 AM
Eh??????????
You know the T4 is an electric car so no use of a receiver battery?
The BEC of most ESC's is set to 6v but there are plenty out there that are programable to other voltages.
