Can a 4 pole sensored motor use with any ESC ? >
Like Tree1Likes
  • 1 Post By foosoomin
Old 05-19-2024, 05:33 PM
Default Can a 4 pole sensored motor use with any ESC ?
Hi all,
As per question stated above.
Possible to use on any ESC ?
foosoomin is offline
Old 05-20-2024, 04:18 AM
rustyus's Avatar
I'd generally say yes, but depends on if it's connected to an ESC via a sensor cable, and if ESC can be programmed into different sensored/hybrid modes. I've ran plenty of sensored 2-pole/4-pole motors with ESCs that are sensorless only... no sensor cable... motor acts as a sensorless motor. Some ESCs will state in the manual if a matching brand of motor is needed for full sensored mode/use. Just read the manual!
rustyus is offline
Old 05-20-2024, 06:09 AM
rustyus
​​​​​​I plan to use a Hobbywing Justock Handout Spec 13.5 turn sensored brushless 4 pole motor on a 1/10th scale 2wd buggy.
I am assuming most ESC able to support the motor
Old 05-20-2024, 06:13 AM
What about a ESC which doesn't state whether support 4 pole motor or not ?
Can I assume the ESC no issue with 4 pole motor ?
Old 05-20-2024, 07:30 AM
R/C Tech Elite Member
Mac The Knife's Avatar
Trader Rating: 33 (100%+)
What esc do YOU want to run it with?
Mac The Knife is offline
Old 05-20-2024, 08:11 AM
DirkW's Avatar
I wasn't even aware the Justock motors are 4-pole. Last time I worried about 4-pole motors and ESCs for them was when I ran 4WD SCT. Not sure what ESC I used back then... Hobbywing?
Justock motors should work with normal ESCs, but if you want to be 100% sure, buy a HW Justock combo.
DirkW is offline
Old 05-20-2024, 10:22 AM
Originally Posted by foosoomin
rustyus
We run a crap ton of these at Hobby Action in our Spec Classes. I have yet to see an ESC they wont work with. Maclan, R1, Muchmore, Reedy, Tekin, and of course, HobbyWing.
BigBuckORamma is online now
Old 05-20-2024, 03:58 PM
gigaplex's Avatar
The handout one is 4 pole but the others in the size class are 2 pole.
gigaplex is offline
Old 05-20-2024, 04:55 PM
Mac The Knife
I intend to run this motor with Sanwa Super Vortex Zero ESC
Old 05-20-2024, 04:57 PM
Thank you for your answer BigBuckORamma
I will assume that my Sanwa Super Vortex Zero ESC able to support this motor
Old 05-21-2024, 01:10 AM
I see no reason why it wouldnt.
Only piece of advice i can give with that motor, is watch the temps, and gear down accordingly. They dont last long when overgeared.
Old 05-21-2024, 01:27 AM
Thank you for your great answer BigBuckORamma
BigBuckORamma likes this.
Old 05-27-2024, 12:19 AM
BigBuckORamma
You are right, my Sanwa Super Vortex Stock ESC is able to run the 4-pole sensored motor.
The motor gets warm (not hot) after buggy run, no issue right ? It doesn't gets hot
