Stronger springs in Futaba 4GRS >
Like Tree1Likes
  • 1 Post By ryan73
Old 05-19-2024, 06:02 AM
Dan the Man's Avatar
Trader Rating: 41 (100%+)
Default Stronger springs in Futaba 4GRS
Running a Futaba 4GRS stick radio. Lovely radio, but it could have a stiffer spring setup. I've adjusted the spring tension up to the max tension inside the transmitter, but after using my friends SANWA Exzes, that has some very strong springs which I liked a lot. All I've found in googling around is replacement springs, no optional ones. Could you shorten the standard springs to increase the tension? I'm also wary that a stronger spring could cause the mounting point to fail, but I really like the strong feedback feel with the SANWA setup.
Any advice from the Stick Radio Mafia? No, I'm not buying a SANWA
Dan the Man is offline
Old 05-28-2024, 06:19 PM
Default Stick spring
Been using futaba 4grs for years now and never changed anything other than 7-3 for smoother throttle control.
You got me thinking about spring stiffness thou.
I am sure you could cut a coil off the existing spring or something.
Dan the Man likes this.
ryan73 is offline
Old 05-29-2024, 02:20 PM
I thought about trimming a few coils off the springs, but I think I'll wait and get an extra set to hack away on. Now I just have to find the part number, then find someone who stocks Futaba springs for old transmitters. Should be super easy
