How to figure out brushless motor amp draw
How can we figure out a motors amp draw rating? Im shocked not to see manufacturer ratings of this like from Tekin even doesnt list it on their site!
I thought these companys used to provide amp ratings. how are we supposed to properly spec out a brushless system without knowing amp ratings? Now my lipo is rated for 850 amps which is very plentiful but I'd still like to know the Tekin truggy motor amp draws. |
A motor analyzer will give you all this info plus more. Higher end manufacturers dont really list it if their motors have adjustable timing. A lower timing can draw as little as 3-4 amps and a higher timing will pull 6-7 amps although thats towards end of the performance window.
DISCLAIMER EDIT: This advice is based on 17.5 blinky motor. Nonetheless you need a motor analyzer and side question - is it okay to attach the alligator clips to a motor on the car or do you need to unsolder it? |
I think brushless 1/8 motors pull much more amps than 7, regardless of any timing or not.
Under real life loads, all motors will pull more than these numbers. ;)
Originally Posted by sn47som1
(Post 16055334)
Originally Posted by Andy Koback
(Post 16055339)
Sent you a PM.
But yes, there is no way to get specific numbers. The amp draw is depending the weight, gearing, 4wd/2wd tires and the type underground. Only with a datalogger that some high end ESC's have you can see the amp draw. |
Originally Posted by Roelof
(Post 16055353)
Nothing to share here?
As soon as you throw a load on the motor the amp draw will go up. It varies with the load.
I understand the amp changes with timing, what I’d like to know from the manufacturer is what is the target amp rating for the motors thermal design. That would take a lot of guess work out of adjusting the timing. My guess is that is known because the factory tuned motors, like Fantom Works, seem to target a specific amp draw for the use case. This is based on observations reading motorlyzer printouts from a few Fantom Works and Slot Machine Certified.
(Post 16055389)
I've used the "Sams Rev Meter" for this purpose. Simple meter that connects between the ESC and battery. Free rev will show amp draw and you can adjust timing to get the draw you're looking for. Inexpensive little unit that we used for pan car oval.
But as explained, it is a crap tool, it tells you a load at free spinning wheels, wow. My simple 20 dollar multimeter can do that too, nothing special. It does not tell a thing about the real amp draw while driving. |
Originally Posted by shortcut3d
(Post 16055423)
Your amp draw will fluctuate wildly while driving depending on the load the motor is under at that moment. Kinda hard to say "the amp draw is such and such."
Originally Posted by staiguy
(Post 16055324)
(Post 16055423)
The goal is not for timing, thermal or heat analysis. I need to know the max amp draw from the motor at its highest level, full burst. This is one of the best ways to spec out a highly efficient brushless system with lots of headroom right? If my battery is rated at 850 amps, and lets say my Tekin motor pulls a max of 150 amps, then I would have tons of headroom from the battery and wouldn't even come close to overloading it.
| All times are GMT -7. It is currently 08:25 PM. |
