-   -   Lipo Question (https://www.rctech.net/forum/radio-electronics/1118381-lipo-question.html)
Bsud 11-25-2023 06:44 AM
Lipo Question
I've got several lipos that's been in my shop in a fireproof charging bag for a few years. I haven't ran any of my cars in this time. Would these be ok to use and or how do I know that they are ok? Some of them are hardcase so not sure how to tell if cells are puffed. Also the stickers has worn off of some and I'm not sure if they are 2s or 3s batteries. I need some help on this???
Goof 11-25-2023 07:23 AM
They might not be good, There's that white little plug. Plug that into the charger and see what they read. If they don't read anything it' dead . You want them to be above 3 V. Per cell You could storage charge them and then check them every 3 months when you get new ones.
YouTube can help u ... watch Storage Charging your lipos
riceball777 11-25-2023 12:07 PM
i stop racing and have not used my lipos in 2020. I just started racing again a few months ago and all my lipos did not loose any voltage. they were all storage at 3.85 volts per cell and they were still at 3.85 volts 3 years later. They all still work perfectly fine
Sabin 11-25-2023 12:48 PM
As long as there's no physical damage - swelled packs, and if the voltage is anywhere between 3.75-3.85 volts/cell, you'll be okay.
Bsud 11-25-2023 01:23 PM
So will the hard case packs swell up? I know soft case you can see them if puffed or swelled but wasn't sure about the hard case
DirkW 11-25-2023 01:30 PM
Yes, they will swell up, too. Those hard cases aren't all that thick and sturdy.
billdelong 11-26-2023 09:29 AM
Answered the same question on a cross post over here:
https://www.rctalk.com/forum/threads...3/post-1404545
Only way to know for sure is to check the IR of the cells.
Thamoss 12-10-2023 11:02 PM
There's a possibility they might not be in optimal condition. Look for a small white plug; connect it to the charger and check the readings. If there's no response, it might be dead. Ideally, you want each cell to be above 3 volts. Consider storage charging them and periodically checking every three months, especially when acquiring new ones.
biz77 12-11-2023 01:05 PM
Bots doing bot things.
Sabin 12-12-2023 12:39 PM
They'll swell if they're not kept in good condition. It won't be as pronounced as with a soft case, and if they're swelled enough, the case will crack.
