-   -   Is 10A really enough (https://www.rctech.net/forum/radio-electronics/1118360-10a-really-enough.html)
Cody_ferone 11-24-2023 05:49 AM
Is 10A charging output enough
and go
DirkW 11-24-2023 05:58 AM
Enough for what? Over here most tracks and racing series nowadays have a limit of 12A - not all that much higher. IMO 10A is enough for most people.
If you're racing with folks who do the whole 40A+ thing and believe you're a good enough driver (being marshaled just once will cost you way more than you will ever gain by high amp charging) that it truly matters and are willing to replace your batteries accordingly, then no.
1995 Monster T 11-24-2023 06:14 AM
Fast charging kills batteries fast.
Roelof 11-24-2023 06:26 AM
10A for an 8000mAh battery is just slight more than 1C, what fast charging??????
gigaplex 11-24-2023 02:21 PM
Maybe they meant that going more than 10A is bad, so 10 is enough?
gigaplex 11-24-2023 02:22 PM
and go
10A is the legal limit where I race, so yeah definitely "enough".
riceball777 11-24-2023 04:43 PM
It depends on what enough means. 10amp is is enough to go racing and be usable sure. But am I personally ok with only having 10amp is of power then the answer is no. I personally use a icharger 458 with a 24 volt power supply. The reason I have this charger is because I like charging at 45amps and I like have 1500+watts of available power. No it’s not necessarily but I like it.
it’s like saying is my 200hp civic enough. Sure it enough for basic commuting but I sure as hell won’t like it or enjoy it.
Sabin 11-24-2023 06:11 PM
and go
Yes. It's actually a bit too much. Lipo batteries like 1 to 1.5C charge rate. They're not NIMH batteries where you can charge at a billion amps to get a bit more punch.
Roelof 11-25-2023 12:13 AM
Originally Posted by riceball777 (Post 16052814)
It depends on what enough means. 10am is is enough to go racing and be usable sure. But am I personally ok with only having 10amp is of power then the answer is no. I personally use a icharger 458 with a 24 volt power supply. The reason I have this charger is because I like charging at 45amps and I like have 1500+watts of available power. No it’s not necessarily but I like it.
There is another reason why we have limited charging currents. It is to keep the mains fuse alive. Most normal clubs have a 35A fuse on the incoming 230v, that is 8000w. If you have a race with 100 drivers and everyone is charging at 40A (+/- 350 watt) then only 20 people can charge batteries before the fuse gets critical.
riceball777 11-25-2023 12:30 AM
lipo’s can charge much much faster than 1c with out any problems. Now a days more of the fast stock 17.5 racers cycle the batteries at 40-45 amps. Even the basic 18650 and 21700 lithium ion cells in my tesla charge at over 3c on the super chargers and these basic 18650 cells can’t charge close to as fast as rc lipo’s. I generally charge at 15-20 amps when I’m not in a rush. But many time I just charge at 45 amps.
riceball777 11-25-2023 12:31 AM
absolutely if this is an issue then require everyone to charge at a much slower rate. I generally don’t run into this issue. Any where I go or if I’m at home.
billdelong 11-25-2023 06:59 AM
balance current will be far more important, I charge my packs at 20A with average charge time of 10-15 min, when a pack takes longer than 15 min to charge, the IR is fading at that point and it's time to replace the battery, more info here:
gigaplex 11-25-2023 07:34 AM
Balance current is irrelevant if your cells are closely matched. It only matters if the charger detects a voltage mismatch.
Sabin 11-25-2023 07:48 AM
Bad practice, reduces total mAh capacity, and kills the longevity of the lipo. Also, that risks a fire. Don't do it.
billdelong 11-25-2023 05:33 PM
Balance current is key, it will significantly improve charge times for a degrading pack that would otherwise need to be replaced far too soon with a charger with a poor balance current rating.
I once had a low quality charger that didn't provide any balance current rating and my battery took close to 45 min to charge at 10A and a buddy at the track put the battery on his iCharger to test the IR for me and showed how the IR was a little high but not bad and he charged it in 15 min at 10A and that's when I was convinced that balance current was the most important thing that mattered. I bought an iCharger the next day and never looked back at any of the budget chargers ever again ;)
