Like Tree242Likes
Radiomaster MT12
Old 05-16-2024, 05:53 PM
  #436
No, I use paid 3D CAD.
Chof is offline
Old 05-21-2024, 06:25 PM
  #437
Are there any noises on whether this radio has an incoming update bringing it more in line with the TX16 air radio, i.e big screen, more dials and upgrade parts?
Zoomies is offline
Old 05-28-2024, 09:39 PM
  #438
Coopz's Avatar
Trader Rating: 22 (100%+)
I just ordered one, didn't really need a new radio but I do have a Radiomaster TX16S for my RC helis and its without doubt the finest radio I've ever had (and I've had a lot..). Once I got my head around the rather complex setup process it was a breeze and people at my RC club who originally knocked it as 'Chinese s--t' started trying it, realising how advanced it was compared to the mainstream radios, also started buying them, I'm going to assume the pistol radio is the same.
Coopz is offline
Old 06-03-2024, 11:41 PM
  #439
I'm quite happy with mine. As I've mentioned in this thread, I'm really into open source solutions - we will be able to fix any issues with the hardware even if the manufacturer goes out of business or sunsets the model. No more dealing with artificial market segmentation and missing features on a low-mid range radio.
I just flashed the firmware up to the latest ELRS. Haven't updated the EdgeTX yet but I'll look into that next.
RCscale is offline
Old 06-05-2024, 07:13 PM
  #440
RetroThutmose's Avatar
Very happy with this radio so far. I just installed a Rx in my "serious" car. I am running it tomorrow and hope to get it dialed in by mains. I was doing initial binding and setting steering endpoints and was thinking about the open source nature of this radio. Would it be possible to connect the radio to a PC and run a program that can make adjusting the controller easier? I'd like to use some of the knobs for adjusting power limits but I find the process daunting and not sure if the knob is the most accurate way to adjust. Anyways, I thought it would be cool if I could program the radio using a gui-based program, don't know if that's a thing.
RetroThutmose is offline
Old 06-05-2024, 08:31 PM
  #441
There's something called EdgeTX Companion that may do what you want.
RCscale is offline
Old 06-08-2024, 07:35 PM
  #442
ta_man's Avatar
Trader Rating: 168 (100%+)
I've looked around a little on the 3D printing sites but didn't find what I want so asking here:
Does anyone know of an extension that will move the steering wheel housing about 1/3 to 1/2" away from the radio body so a person who uses the right hand for the throttle has more room for the knuckle of their trigger finger (which, for me, hits the steering wheel housing as manufactured).
If you are curious why anyone would want such a thing it is because due to an accident in my youth my left index finger is too short to operate the throttle trigger if I hold the radio in the conventional way.
ta_man is offline
Old 06-12-2024, 07:45 PM
  #443
RockinTheCasbah's Avatar
Trader Rating: 7 (89%+)
Anyone know when the mt12 will be compatible with companion ?
Also it's anyone selling different sized brake trigger halfs ? Or have a stl link
Edit : brake triggers are on thingaverse 10 minute print , you might have to shave a little bit to get it fit correctly unless your printer is really dialed in.
RockinTheCasbah is offline
Old 06-17-2024, 08:03 PM
  #444
Going to test using the mt12 internal elrs in 1/8
Off-road, I think it's faster then the nb4 pro so why not run them back to back. Tele is off to reduce latency , internal power is 250mw with dynamic off. Is that my best bet for fastest transmission and lowest packet loss ?
Old 06-19-2024, 02:07 AM
  #445
Update post above , dynamic on or off it defaults to full power with tele off.
​​​​​​Second update from my very issue
anyone experiencing the programmable sevo or esc problems on channel one due to the reciever sending a pwm burst at the beginning of boot and making the esc or servo look for a programming signal .
Remap your receiver outputs so the affected servo or esc is on a different pin out 1 to 2 1 to 3 etc.
I was struggling to get it to work right with a hobbywing 2n1 system it would not let you calibrate unless you unplugged the servo and plugged it back in , then wouldn't work on restart .
Tried again in my ebuggy with a XR8g2r , same symptoms, was about to put my nb4 pro receiver back in , watched some videos , and realized the pwm burst issue is only one channel , remapped the receiver via web app and works without any issues.
Frustrating at first, but the ability to easily remap output pins on the receiver shows flexibility that other systems would need a firmware update to fix , if that even worked
Old 06-19-2024, 02:12 AM
  #446
gigaplex's Avatar
That issue has been discussed earlier in the thread. It's a hardware bug of the receiver.
gigaplex is offline
Old 06-19-2024, 02:48 AM
  #447
I think we need a sticky for this thread
Old 06-19-2024, 05:05 AM
  #448
RC10Nick's Avatar
Another key piece of info that should go into any sticky should be checking and updating the ELRS firmware to make sure you're not running the 3.3.x firmware since that version had issues with signal loss causing runaways.
gwhiz and RetroThutmose like this.
RC10Nick is online now
Old 06-21-2024, 04:18 AM
  #449
well crap, i just came here to post about a runaway i had during practice at the track last night, now i know where to start checking. is that the firmware on the rx or tx?
gwhiz likes this.
Old 06-21-2024, 07:16 PM
  #450
gwhiz's Avatar
Unhappy
Similar.
I had a runaway on my first outing. Only half throttle or so. No steering. It was only a few seconds, but it felt like an eternity.
A little while later I had about 5 seconds of nothing. No throttle, no steering.
It lowers your confidence in a piece of equipment.
gwhiz is offline
