Brushless Motor Rebuild / Upgrade >
Like Tree10Likes
Old 11-29-2023, 07:59 AM
  #31
Originally Posted by trilerian
Clean the tabs of solder. You can use solder wick, a solder pump, or some braided wire with flux (essentially solder wick). The reason why the solder job doesn't look as good the next time is because all the flux was used up/burnt off. New solder with flux works wonders, but you have to get rid of the old solder or you just have a mess. For cleaning off flux you can use 99% IPA or brake cleaner.
Soldering iron temperature is also very important. Depending of the type of solder wire you use.
Mine is settled to 390C. My Pit Space soldering kit. And i use 63/37 solder wire.
shortcut3d likes this.
TheRay57 is offline
