1/10 TC Capacitor placement and connection
I was wondering if i really have to solder my caps directly on my ESC or whether i could add a JR connector to it and just hook it onto my receiver?
Would there be any measurable drawbacks, or perhaps just not work at all? It would make swapping out parts allot easier for me |
Basically you can use a connector but it will not help with getting a low ESR and a reliable working (that if the connector makes a bad contact).
Originally Posted by JSHuiting
(Post 16022086)
+1
Also, do not confuse these caps with a glitch buster - they serve a different purpose. |
Did overlook the part to put it in the receiver. that is not the same as mentioned. You can solder a wired connector to the battery tabs of the ESC and connect the capacitor to it.
Originally Posted by DirkW
(Post 16022148)
+1
Also, do not confuse these caps with a glitch buster - they serve a different purpose. But are glitch busters still necessary? Or was that a nimh/brushed era relic? |
Most modern ESCs have powerful BECs, so unless you use exceptionally power hungry servos, there is usually no need. Personally I have never had to use one.
| All times are GMT -7. It is currently 09:01 AM. |
