Direct Power HV Servo
I am interested in trying this with my 1/8 buggy (HB D819) here is my dillema;
I want to use a 3s lipo for power and am not sure if this will damage my reciever which is a Hitec Axion 2. How can I get the 3s power to the servo but keep the voltage to the reciever at 2s nominal voltage - I am not sure if this reciever can handle 3s if it can problem solved maybe? Miraculously I have found a 3s lipo that will fit my radio tray but really leaves little room for any additional wiring - considering the steering servo wire routes through the battery box on the HB. Any advice will be appreciated and I can answer any questions you might have if I have left something out. |
What servo are you using that can handle 3s direcly ?
A robot servo. 3 cells on a rx No way. use a ubec to drop voltage down
The direct power HV servos I have used wire directly to the battery. The plug in the RX is just for signal, no HV.
https://holmeshobbies.com/electronic...-lp-servo.html |
Hv servo
I plan to use a similar servo to this but how do I take that 3s lipo voltage down so it does not fry the reciever? BEC?
Ok rcguy I will give that a look.
HV servo
Originally Posted by mrreet2001
(Post 15963543)
Originally Posted by MXRCF1
(Post 15963668)
There are more and more available nowadays.
(Post 15963666)
Put A BEC on the same leads that power the servo and bump it down and plug it into the RX. I power the RX from the built in BEC of the ESC. There are only 2 wires going from servo to RX, a ground and a signal. No voltage. |
statement retracted.
I don't make the servo, I just use it.
And they all have two wires going to the RX. Perhaps to prevent a floating ground? https://cimg7.ibsrv.net/gimg/www.rct...b614339033.png https://cimg9.ibsrv.net/gimg/www.rct...3b668223dd.png |
You can make your own harness similar to this method here by using the balance port of the battery to draw 3S:
https://www.rcgroups.com/forums/show...0#post40061288 |
Originally Posted by Precision1
(Post 15963730)
I run direct power servos in 4s its not a problem at all just make sure to get a 4s servo. The power they have is ridiculous and speed is impressive.
Re: Hv Servo
Originally Posted by KINGZJ
(Post 15963773)
| All times are GMT -7. It is currently 04:54 AM. |
