-   -   HV Servo hook up (https://www.rctech.net/forum/radio-electronics/1106123-hv-servo-hook-up.html)
Brit_racer 11-08-2022 01:26 PM
HV Servo hook up
So when you have a servo that is faster at 8.4v do you hook up the red wire to the 2c lipo you are running as I realize the receiver will only give it 6.0v?
And then leave the other two wires in the receiver plug? Anyone know of a plug that will do this or just re-wire myself?
I remember back in the 90's the KO Servo and a 4th wire coming out of it for the high voltage. It was the PS 1001 fet servo.
the rc guy 11-08-2022 02:59 PM
you build Y splitter for battery and power it thru that.
gigaplex 11-08-2022 03:49 PM
Or alternatively some ESCs can configure the BEC voltage output. It's not the receiver that defines the available voltage.
disaster999 11-08-2022 05:10 PM
Just keep in mind the battery voltage will not be constant when you run your vehicle. it will spike up and down depending on the driving and demand of the motor/esc. This will affect the servo steering speed if you hook it up directly to the battery giving you inconsistent steering speeds and would probably affect your driving. The BEC on the ESC might not go up to 8.4V, but at least the ESC will supply a consistent voltage supply throughout the battery's voltage range.
Roelof 11-09-2022 01:09 AM
Or just think if you do need that extra speed or ask your self is a better servo would be an answer.
billdelong 11-09-2022 09:41 AM
gigaplex 11-09-2022 01:15 PM
And then that better servo will probably also be faster at 8.4V so they'd just be asking the same question again.
billdelong 11-09-2022 01:24 PM
HV also boosts torque which can improve efficiency/temps and put less strain on the BEC which can help extend the life of the electronics all the way around.
Brit_racer 11-09-2022 06:07 PM
Thanks everybody!
