Bullet Connectors for HP power supply >
Old 08-11-2022, 11:19 AM
Trader Rating: 26 (100%+)
Default Bullet Connectors for HP power supply
I have my own converted hp power supply that I have been using with my 406 duo for awhile now. For the female bullets I just used some panel mount ones I had for something else, but I'd like to get the correct ones, black and red (or is that just shrink tube?) like they have on the RL supplys and whatnot.
Can anyone point me to a link for the actual thing? I searched the forum here for quite awhile and everyone talks about it, but I can't find a link anywhere. Or maybe my searching is sub par lol.
{tpc} is offline
Old 08-11-2022, 11:26 AM
Roelof's Avatar
It is called a banana plug, on ebay, amazon, aliexpress and even your local radioshack has them in all kinds.
The RL power supplies just have shrink wraps
Roelof is offline
Old 08-12-2022, 10:00 AM
Trader Rating: 33 (97%+)
I just use shrink tubing to keep things simple:
https://www.rcgroups.com/forums/show...0#post43199655
billdelong is offline
Old 08-14-2022, 03:46 PM
is there a RadioShack where you live??
ballardrc is offline
Old 08-14-2022, 11:14 PM
Roelof's Avatar
I have some electronic parts stores where I can go to but most I order online.
Roelof is offline
Old 08-15-2022, 07:25 AM
Hobbytown USA has all the good stuff.
waitwhat is offline
Old 08-16-2022, 04:59 PM
GerryH's Avatar
I've built and sold a couple dozen power supplies. Get a set of bullet connectors, you need some where the wire side is flat. Some have a small cutout for the wire for 90 degree bends, avoid them. Mark out where you want your connectors to be on the + & - tabs. I just use a pencil on the edge of the connector. Tin those areas with solder a little bigger than the bullet connector. Now this is the tricky part, solder the bullets to the connector. You'll need more solder and you need to make sure it flows completely around the bullet. I built a jig out of wood that holds the bullet connectors while I solder them. When everything has cooled off, I try wiggling the bullets with needle nose pliers to make sure I've got a good solder joint.
Then you need red and black shrink wrap to finish them off, 3/16" is a good size.
GerryH is offline
Old 08-16-2022, 11:15 PM
Why not just use a breakout board and some connectors? X8/X11 bobs are pretty cheap.
I have a whole stack of 1200/1400/2400w server power supplies here.
Licklobster is offline
Old 08-17-2022, 10:14 AM
mrreet2001's Avatar
Because Bullet and XT connections are pretty much the standard in RC not PC molex.
mrreet2001 is offline
Old 08-17-2022, 01:12 PM
OffRoadJunkie's Avatar
This might help. Crude, but non the less, it might help.
OffRoadJunkie is offline
Old 08-17-2022, 10:48 PM
Sure, but its a lot more durable to solder to wires then it is to the thin metal of the connectors.
They also make psus with lug terminals, which would be even easier for this purpose.
Old 08-18-2022, 05:08 AM
mrreet2001's Avatar
If you don't have decent soldering skills, you probably shouldn't be modding a power supply.
