Adjusting endpoints to match subtrim
Had to adjust the subtrim on my steering servo slightly to get straight. How do I properly set my end points after to keep my steering proper?
Originally Posted by Jaredf
(Post 15925456)
I always took a solid side ran my car half a circle with steering wheel all the way in that direction then did other way , I adjusted endpoints in my radio to match.subtrim takes away from whatever direction you use it in.
Correct order is:
1. Trim at zero and dual rate at 100% (ideally a fresh model memory) 2. Sub trim to get the linkage geometry correct (right angles are your friend) 3. EPA to get full lock, no more, no less, in each direction 4. Trim to get the car running straight on the track (won't need many clicks after correct sub-trim setup) 5. Dual rate to reduce steering if necessary for handling balance |
Originally Posted by sosidge
(Post 15925583)
Correct order is:
1. Trim at zero and dual rate at 100% (ideally a fresh model memory) 2. Sub trim to get the linkage geometry correct (right angles are your friend) 3. EPA to get full lock, no more, no less, in each direction 4. Trim to get the car running straight on the track (won't need many clicks after correct sub-trim setup) 5. Dual rate to reduce steering if necessary for handling balance I use a setup station to set the ride height, camber and front toe first...then I adjust the link between the servo arm and the bell cranks to get the car to track straight. It can be time consuming but it's worth the hassle to know my car is perfectly centered. Not all radios will balance steering properly even with sub-trim where a few points is no big deal, but I've seen some guys have close to 50 points on their sub-trim where I test drove their car and could clearly feel unbalanced throw from left to right making the car harder to drive than necessary. Once we centered everything out the car drove like a dream. |
I mis the step of mount the servosaver or servo arm as close to center as possible
Originally Posted by billdelong
(Post 15925626)
I really like this approach but I will go a step farther with an initial car setup where I prefer to never touch trim and keep sub-trim to zero.
(Post 15925626)
I use a setup station to set the ride height, camber and front toe first...then I adjust the link between the servo arm and the bell cranks to get the car to track straight. It can be time consuming but it's worth the hassle to know my car is perfectly centered. Not all radios will balance steering properly even with sub-trim where a few points is no big deal, but I've seen some guys have close to 50 points on their sub-trim where I test drove their car and could clearly feel unbalanced throw from left to right making the car harder to drive than necessary. Once we centered everything out the car drove like a dream. Martin Paradis |
Originally Posted by rhodopsine
(Post 15926510)
I agree that your method works fine, but sometimes, getting the servo perfectly centred can be between 2 teeth of the servo output shaft, therefore you need to use the sub trim to get it in the correct position. It is especially true with pan cars.
Martin Paradis |
Originally Posted by gigaplex
(Post 15926542)
That's why you adjust the length of the link between the servo horn and the steering rack, like they mentioned. But yes, this won't apply to pan cars.
Martin Paradis |
(Post 15926545)
on most pan cars, there is no steering rack… The servo saver is directly connected to the tie rods. You want the servo saver center to be exactly perpendicular to the chassis and the tie rod to be exactly the same length. Otherwise you will end up with asymmetric steering.
Martin Paradis |
| All times are GMT -7. It is currently 05:41 PM. |
