Like Tree53Likes
iCharger DX8
Old 05-12-2022, 03:22 AM
  #46
Roelof's Avatar
There seems to be a bug in software 1.03. The current limiter on the input does not work so with a high power demand on a low input voltage you can fry the charger.
The fixed firmware 1.05 can be downloaded here: https://ddownload.com/6nr6r2n5mjq3/DX8_V1.05.zip
Roelof is offline
Old 05-12-2022, 05:12 AM
  #47
So when you fry your charger due to a firmware issue, do they replace it?
Silverbullet555 is offline
Old 05-12-2022, 06:03 AM
  #48
Roelof's Avatar
That I do not know but if it is warranty they should solve it either in a replacement or a repair.
Roelof is offline
Old 05-12-2022, 12:01 PM
  #49
Midnight's Avatar
Trader Rating: 87 (100%+)
Is it possible to update using MacBook?
Midnight is offline
Old 06-05-2022, 09:06 AM
  #50
Livewire121's Avatar
Can I use my current 2s discharge back from one of my X6s to get a higher then 15a discharge, when discharging a 1s? On the DX8
Livewire121 is offline
Old 06-05-2022, 09:25 AM
  #51
Roelof's Avatar
I think so, but you can download the manual and look it up.
Roelof is offline
Old 06-13-2022, 01:18 AM
  #52
Anyone has a lead on when the DX6 will come out?
Have no need for 8s, so would like the (assumed) smaller footprint.
Toet is offline
Old 06-26-2022, 08:11 PM
  #53
Default Discharging by combining both channels?
My dx8 interns discharger current is around 5.6a per channel. Is it possible to discharge a 2S battery by combining both channels so it’s 10amps?
b3dlam is offline
Old 06-26-2022, 08:54 PM
  #54
gigaplex's Avatar
Sort of. You can do it but it'll only get you 70W (roughly 8A).
b3dlam likes this.
gigaplex is offline
Old 06-27-2022, 05:54 AM
  #55
If you want full discharge capacity without adding a resistor block you can set up your charger to discharge one battery while charging another.
Pages 33 & 34 of the manual tell you how to set up your charger to do this.
b3dlam likes this.
waitwhat is offline
Old 07-18-2022, 11:31 AM
  #56
Anyone else think the wheel is a little difficult to turn? It definitely doesn’t glide smoothly like my 406duo.
malkiy is offline
Old 07-18-2022, 07:35 PM
  #57
What’s the main benefit of that charger? Is it worth the price?
RacingRookie27 is offline
Old 07-19-2022, 05:46 AM
  #58
mrreet2001's Avatar
You will need to use the "Firmware Upgrades via SD Card" method.
mrreet2001 is offline
Old 07-19-2022, 01:29 PM
  #59
Advantages:
1. Smaller and lighter than a 306duo (half the weight and about 1/3 smaller).
2. 2amp balance current
3. Don't know if it's true but people say it's more accurate.
4. Has capabilities of the 306duo when paired with an external discharger
5. Some places, like progressive rc, are selling the charger for $250. Cheaper than the $270 for the 306duo.
6. Shows charge and discharge capacity for each cell.
Disadvantages:
1. IMO the kickstand doesn't angle the charger enough for good screen visibility. I can see why though, the charge cables would get in the way.
2. Low internal discharge capabilities for those without an external discharger. A little less than half the current of the 306duo.
3. Scroll wheel isn't a smooth as the old design.
malkiy is offline
Old 07-19-2022, 01:44 PM
  #60
Default 406duo vs dx8 size comparison
malkiy is offline
