iCharger pit set up
After pics and pointers on any cool stands/organising equipment for an iCharger set up
I’m in two minds between a peli style case build where the charger is fixed within the hard case and very well protected and portable or a more traditional carry case with a folding stand etc |
Originally Posted by EvilR2.0
(Post 15881798)
I’m in two minds between a peli style case build where the charger is fixed within the hard case and very well protected and portable or a more traditional carry case with a folding stand etc The built in will take up a lot of real estate on your pit table. I use one of the 3d printed mounts, probably from RL, that slides over the power supply and the icharger is right up on top. It's compact and all together. |
Originally Posted by Silverbullet555
(Post 15881803)
I almost bought a setup that uses the rigid cases to house the icharger. If I was racing out in an open environment, that still might be a consideration. But, I race indoors so it isn't.
The built in will take up a lot of real estate on your pit table. I use one of the 3d printed mounts, probably from RL, that slides over the power supply and the icharger is right up on top. It's compact and all together. This is my bench set up https://cimg3.ibsrv.net/gimg/www.rct...3bb80a847.jpeg https://cimg6.ibsrv.net/gimg/www.rct...85ae4b89e.jpeg |
Here's my setup, i designed the 1200w hp power supply enclosure and the i charger stand, everything fit inside the apache case from harbor freight.
https://cimg9.ibsrv.net/gimg/www.rct...d5f7159064.jpg https://cimg2.ibsrv.net/gimg/www.rct...081f3de8ff.jpg https://cimg3.ibsrv.net/gimg/www.rct...ba34b7e173.jpg https://cimg4.ibsrv.net/gimg/www.rct...f65d7c13a0.jpg https://cimg7.ibsrv.net/gimg/www.rct...07c141ba3f.jpg https://cimg7.ibsrv.net/gimg/www.rct...be6dc2a54d.jpg |
Thats looks very neat. Is that a 3d-printed stand?
https://cimg1.ibsrv.net/gimg/www.rct...a6553b7e5.jpeg
I keep mine pretty simple |
Originally Posted by Toet
(Post 15882755)
Originally Posted by Specialblend_73
(Post 15882917)
Hi, yes, stand and power supply enclosure are 3d printed.
Is your icharger and power supply 3d print files available anywhere? Cheers |
Does any one know where to find, or have a file on s6 stands. I will be needing them for outdoors this season, as I have a different PSU for outdoors. I use RCdischarger indoors.
| All times are GMT -7. It is currently 08:54 PM. |
