-   -   Balancing wire (https://www.rctech.net/forum/radio-electronics/1095391-balancing-wire.html)
Phillip F 01-30-2022 01:57 PM
Balancing wire
Does anyone know if you someone sells just the balancing wire instead of the wire and the balance board? If so... where can I buy it... link?
https://live.staticflickr.com/65535/...aa0faff152.jpg
Roelof 01-30-2022 02:35 PM
just goohle to "balance board connection cable"
even Amazon has them
the rc guy 01-30-2022 03:01 PM
yes
Phillip F 01-30-2022 05:38 PM
tried that and cannot find the right cable.
lowspark 01-30-2022 06:22 PM
Amain Hobbies> search Balance Cable
Phillip F 01-30-2022 06:40 PM
they only sell the balance board w/ cable
belewis01 01-30-2022 08:21 PM
Try Progressive RC
Geezatec 01-30-2022 08:25 PM
Any EBay, Amazon, Online hobby Store. Search not Balancing Wire, But Balancing Cable. 2S-6S cable, anywhere from 6" - 12".
Santa Clarita huh!!! Used to work out there for HRD.
PDR 01-30-2022 09:08 PM
My chargers use a JST XH connector:
https://www.jst-mfg.com/product/pdf/...?61f76d50b5d63
If you want to make your own, buy some crimps (SXH-001T-P0.6 or similar - see datasheet), and some housings (XHP-3 for 2S, as an example). Use some nice wire away you go.
Roelof 01-31-2022 02:21 AM
How well tried?
One of the 1st hits:
Small tip: sometimes it works better to google pictures
Phillip F 01-31-2022 11:32 PM
Originally Posted by Roelof (Post 15870025)
How well tried?
One of the 1st hits: https://www.amazon.com/JST-XH-Adapte.../dp/B00NBANLEI
wrong one ... .... if you look closely at the wire in the first picture..... connectors are both different.
SFOcean 02-01-2022 12:19 AM
You are looking at two sides of the same connector.
Each end has the same connector.
https://cimg1.ibsrv.net/gimg/www.rct...13ac0b95d1.jpg
lowspark 02-03-2022 08:31 AM
I don't think the OP is looking at the suggestions given to him...
Amain search balance wires
https://cimg8.ibsrv.net/gimg/www.rct...0926d744f6.png
Roelof 02-03-2022 09:24 AM
A new balancing board with wire just 7 dollar..... Why all the fuzz to get a wire?
Phillip F 02-03-2022 05:58 PM
so I can just buy a bunch of wires instead of a thousand balance boards and wires
