Need help with lipo battery
Hi, I'm new to RC's and I have this 5000mah 80c 11.1v lipo I was wondering what kind of ESC I would need to run it, and from my calculations, it has 400amps of continuous power and I have a 45amp ESC
You need an ESC that can handle 3s LiPO to start. The amperage is about what the motor pulls, not what the battery gives.
Welcome to the hobby.
Basic battery stuff: 5000 mAh: this is equivalent to how big the tank of fuel is. More mAh (milliamp hours) = the longer the battery will run for. 3S = number of cells. More cells = more voltage = more power. 11.1v = nominal voltage. It can be charged to 4.2v/cell if it is a normal LiPo, so 3 cells x 4.2v = 12.6v. C rating = basically marketing garbage. Higher C ratings mean the battery is capable of delivering more amps, but the ratings are not consistent enough and often inflated. In general, it is used as a measure of quality (more C = more better). LiPo safety basics:
Which ESC you need will depend on the size of the vehicle and how it is used. A lightweight 1/10th scale 2WD buggy can use a much different ESC than a monster truck. The motor size and weight of the vehicle will determine how many amps the motor will pull, and the ESC needs to be able to handle at least that amperage. |
wouldn't it be best to get numbers from a fully charged battery rather than a battery needing a full charge
a 3 cell motor will work as long as you keep in the manufactures recommended then fact check what's said.. 3200kv or less motor |
Originally Posted by the rc guy
(Post 15866872)
okay so I have a Surpass Hobby 4370Kv 45a Brushless combo and it supposedly can handle 3s but my motor stutters and heats up when put under load why does it do that and can I fix it and how
When does it stutter? If you're talking from a standing start then yes that is what happens with unsensored brushless setups.
How hot exactly is it getting? What is it installed in? What us the gearing setup? |
If it does it right away (within a few seconds), something is bound up or seized. What vehicle is it? What conditions are you running it in? We need more info.
Originally Posted by Cromulent
(Post 15866875)
I don't follow what you're trying to say. The motor really isn't rated for a certain voltage, they'll take the voltage that's thrown at them and spin accordingly. kV is RPM/volt, so a 3200kV motor will spin 3,200 RPM @ 1V, or 25,600 RPM at 8V, or 35,200 RPM @ 11V.
4370 is not a 3 cell motor 2 cell max thats why its stutters
it only stutters right at the beginning and the track turns freely by hand and is a conversion kit for RC snowmobile and I have a 20tooth pinion and a 56tooth spur gear here's where I got the conversion kit RC creations
rc creations
I thought as long as it did not exceed its max rpm which is 50,000
(Post 15866927)
(Post 15866870)
Basic battery stuff: 5000 mAh: this is equivalent to how big the tank of fuel is. More mAh (milliamp hours) = the longer the battery will run for. 3S = number of cells. More cells = more voltage = more power. 11.1v = nominal voltage. It can be charged to 4.2v/cell if it is a normal LiPo, so 3 cells x 4.2v = 12.6v. C rating = basically marketing garbage. Higher C ratings mean the battery is capable of delivering more amps, but the ratings are not consistent enough and often inflated. In general, it is used as a measure of quality (more C = more better). . EDIT: Actually to be more accurate, larger gage wires would be the equivalent to a larger fuel line. However, it's similar. I guess since the higher the C rating, the lower the battery's internal resistance and this allows you to empty the tank faster. So I would think a more accurate analogy would be the higher the C rate is equivalent to a fuel that has lower viscosity and therefore will flow out of the tank faster. |
| All times are GMT -7. It is currently 01:24 PM. |
