iCharger 406 Duo - LIHV Charging >
Like Tree12Likes
Old 01-03-2022, 11:06 AM
  #16
Originally Posted by Alexv2024 View Post
There are lots of videos on youtube on how to use the Duos.
The middle top button can access a menu that adds new profiles. I have about 8 different profiles I use for Lipos and Lihv's with different amp charges and even lower and higher voltage cut offs.
Like when I race mod and dont need all the horsepower I charge to 4.15 as its more consistent that way and helps the batteries last longer.
many videos but none addressed how to change the end voltage. I use the Tab/Sys button (top center) all the time to change the charge rate but never noticed how to use it to created/add programs. A long push in the Knob takes you to a menu to edit copy add and thatís where I changed the charge end volt cutoff and created a separate program for charging LIHV.
PS. I tied it and figured out how to get it to work😊. Oh so much more straight forward than the damn users guide.
John Wallace2 is offline
Old 01-06-2022, 05:46 AM
  #17
soulcoma's Avatar
Trader Rating: 44 (100%+)
Just select LiHV instead of Lipo
soulcoma is offline
Old 01-06-2022, 07:34 AM
  #18
Easy to do on the new ones, but not on mine - LIHV werenít on the market then😊
gigaplex likes this.
Old 01-06-2022, 07:48 AM
  #19
the rc guy's Avatar
so jw2 there is no software than you can dl ?I dont have A icharger. I run my Schulze
the rc guy is offline
Old 01-06-2022, 09:30 AM
  #20
You should be able to update the software on the 406 to get the most current options.
mrreet2001, gigaplex and Speed 8 like this.
Silverbullet555 is offline
Old 01-06-2022, 10:19 AM
  #21
https://www.progressiverc.com/pages/...er-duo-updates
mrreet2001 and the rc guy like this.
belewis01 is offline
Old 01-06-2022, 10:49 PM
  #22
I dont have a problem, I now have two programs one for LIPOs one for LIHVs. I can change them at the same time on my iCharger, which was my objective. I no longer need updated software😊
No idea what a Schulze is and Iím not particularly curious, except it was my grandfatherís last name😊
Silverbullet555 likes this.
Old 01-06-2022, 10:56 PM
  #23
[QUOTE=Silverbullet555;15861248]You should be able to update the software on the 406 to get the most current options.[/QUOTE
Already talked with Progressive RC two issues 1 no updates for anything before v2.18 and the updater would not open. Anyway I no longer need the update.
Old 04-23-2022, 05:48 PM
  #24
Default New quesation
I've been trying to edit a standard charge profile. I can to everything but cannot remember how to save the changes I've hade to the charge and discharge profiles HELP it is to the NiMH program
Old 04-25-2022, 04:12 PM
  #25
GerryH's Avatar
Trader Rating: 26 (100%+)
Are you using the Manage/Edit path to change the profile? If so, there's a Save option.
GerryH is offline
Old 04-25-2022, 05:04 PM
  #26
yes but that doesnít seem to work
Old 04-25-2022, 06:27 PM
  #27
R/C Tech Elite Member
lowspark's Avatar
I believe you have to create a new name for the battery profile before it will let you save it.
lowspark is offline
Old 04-25-2022, 06:40 PM
  #28
Iíve tried that too - no joy☹️ Something must be going on as it doesnít even seem to be going through the same menu sequence as before. Iíd do a factory reset and go back to the original default settings but Iím afraid it would loose the charge models Iíve ready created
Old 04-25-2022, 07:07 PM
  #29
lowspark's Avatar
I recently wanted to add another battery profile to mine and after a couple of struggles found that I had to start with one of the basic profiles (LiPo, LiIo... etc) before it would let me save with a new name.
Good luck
lowspark is offline
