-   -   Electronics help (what esc) (https://www.rctech.net/forum/radio-electronics/1091798-electronics-help-what-esc.html)
Boodaggy 11-06-2021 11:29 PM
Got a project. Easiest way to describe it would be 2 motors that need to operate either independently or together. Hovercraft and the two motors will be the propulsion and steering. On forward both motors turn, on left turn, left motor stops, on right turn, right motor stops, and on reverse, both motors spin opposite of forward. Any ideas or recommendations?
Roelof 11-07-2021 01:51 AM
You need a V-tail mixer.
Advanced airplane transmitters do have this function but you can also find a simple module. It translate a 2 channel motor/steering into a 2 motor control
gigaplex 11-07-2021 10:09 PM
Agree with this, though to be clear there's no special requirement for the ESC. The mixing is done at the radio level using multiple channels. You'd just need one ESC per motor.
mrreet2001 11-08-2021 06:00 AM
..And make sure only ONE esc is feeding power to the receiver. ;)
