-   -   Wiring for DIY excavator setup (https://www.rctech.net/forum/radio-electronics/1091470-wiring-diy-excavator-setup.html)
Bmister132 10-29-2021 11:54 AM
Hi guys I have a custom excavator project I’m working on. I have a t8FB controller and receiver along with an esc. My throttle will be controlling the brushless motor for the hydraulic pump. I have the 3 valves to control hydraulics on boom then 2 small low amperage DC motors that will control forward and backwards on the tracks, which will have high torque gearing to help keep motor load low. And the last motor will be controlling the spinning rotation of the body. I’m curious what channels I should be wiring each of these controls too. This is my first project with 7 channels
the rc guy 10-29-2021 12:11 PM
a few channels short in iho..10 ch min.
  • Left hand left = Swing left.
  • Left hand right = Swing right.
  • Left hand forward = Stick Boom (Dipper) away.
  • Left hand back = Stick Boom (Dipper) close.
  • Right hand left = Bucket curl in (closed)
  • Right hand right = Bucket curl out (dump)
  • Right hand forward = Main Boom down.
  • Right hand back = Main Boom up.
Bmister132 10-29-2021 12:52 PM
[QUOTE=the rc guy;15838705]a few channels short in iho..10 ch min. Left hand left = S
The left right is one channel running on dc motor
the boom/ bucket movements are run off servos on channels that will open bi directional valves
mrreet2001 11-01-2021 10:13 AM
Put the hydraulic pump on a toggle channel. Why would you waste a throttle control for the pump. :confused:
the rc guy 11-01-2021 10:31 AM
pump will need to be increased and decreased. set psi will work? I dont think so
mrreet2001 11-01-2021 01:01 PM
How often do you need to adjust the pump rpm?
Bmister132 11-02-2021 11:53 AM
yes so I did settle on just setting the pump to a high low toggle. But I still am trying to figure things out for arm movement and driving. I will be using four channels just control arms. Then I have a differential controller for the two DC motors on the tracks. The best solution I can think is two controllers. One for driving and one for arm control. But I know that’s overkill and probably a better solution
mushroomed 11-03-2021 01:35 AM
If you're considering buying second radio, it might just be better to pick up a computerized radio like a Radiomaster TX12 or Jumper T-Lite. This will enable you to set up toggles to set whether your sticks are controlling movement of the tracks or hydraulics at the flick of a switch. A setup like this will give you much more flexibility than your current radio.
