Muchmore IC Controlled Tire Warmers Pro - power source?
Hi all,
I can't seem to find full specs needed for a power supply for Muchmore IC Controlled Tire Warmers Pro
What do you use to power these? (Apart from battery power) Thanks.
I use my Protek Duo 625 to power my tire warmers and portable iron. It has a DC power circuit for pit accessories and works great
Any 12v power source. That can be a simple car battery up to a simple power supply.
From experience I can tell you not to use a higher voltage than the 13.8v I have seen blown up controllers on 15v PSU's
Car battery, clips, and 4mm bullets.
I routinely use a 13.8V 23A power supply. Just did some quick measurements:
- Switched on, but not heating - 0.16A
- Heating four cups - 5.6A
Thank you, this is great.
