Like Tree1Likes
  • 1 Post By Airwave
HOBBYWING XR8
Old 08-29-2021, 01:21 PM
Vintagemodified's Avatar
Default HOBBYWING XR8
Hello everyone... have the Xr8 plus esc ... I race oval track ... I had been using my 2s battery all day . I put some street ties on that had gotten caked up with the wet clay on the infield.. I put an 3s battery in spin the ties out ... I hit the throttle once the ties didn't spin as much as I wanted so I hit it again ... this time the truck flipped over backwards an then I lost my throttle. NOW all my esc does is flash 4 green lights an repeats this over an over is there away to fix this or send it back to hobbywing ... also the programmer doesn't work as well
Vintagemodified is offline
Old 08-29-2021, 02:30 PM
Airwave's Avatar
Literally from the user maunal:
The GREEN LED flashes a short, quadruple flash that repeats (☆☆☆☆, ☆☆☆☆, ☆☆☆☆) indicating the ESC has failed the self test and it needs to be sent back to the factory for test and repair. (In general, the problem is caused by ESC failure, or motor failure sometimes.)
1/8 IC Fan likes this.
Airwave is offline
Old 08-29-2021, 06:28 PM
1/8 IC Fan's Avatar
Trader Rating: 99 (100%+)
And what was wrong with asking in the dedicated HW forum...🤦‍♂️
HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
1/8 IC Fan is offline
Copyright İ 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
