hobbywing OTA vs Program Box
Does the HW OTA provides more adjustment than the Program Box? It seem both needs to be connected to the ESC at some point. Just wondering what is the major advantage of one over the other. Is the connection of the OTA reliable? If you were to buy again, which would it be?
its not more adjustment its more ease of use
the program box you have to click through each option where the ota lets you hop around i like using the OTA alot for copying profiles from one esc to another and making small adjustments while i can see all the options and not have to think ok what one is next or what was previous i just think that using my phone to modify parameters is exponentially easier then the box. however, if youre a set it and forget it type of person the box is probably fine. i like to change drive frequencies, softening values etc often based on track conditions |
It has a lot more adjustments you can fine tune it more than with the programming box also you can use the customized functions
OTA is a no brainer.
Originally Posted by Marcos.J
(Post 15818014)
Ok thanks guys that makes sense. Is there any connectivity issue with the OTA. Have any of you ever have difficulties connecting? I can imagine it would be frustrating if the connection is hit and miss.
Originally Posted by chumanji
(Post 15818094)
Was just about to ask this same question.
| All times are GMT -7. It is currently 09:39 AM. |
