Battery IR
I just checked my 2s 2400mah 7.4v transmitter lipo and it had an IR of 74.5 on one cell and 71 on the other. This seem quite high and the battery is less than a year old. The battery did not swell, is it ok to use?
The current draw is so low for a transmitter, that high IR will not affect anything. I'd use them as long as they hold a charge for a while.
A lot of the IR comes from bad connections, at least for high current draw.
I made a radio battery out of an old race pack, and with a balance connector on and plugged into my Icharger it measures lower IR than without the balance plug. Still though the low power of a radio high IR doesn't matter |
Originally Posted by glennhl
(Post 15813989)
Do you guys pull the pack from the radio and storage charge it? Lipo seems more of a pain for a transmitter.
Originally Posted by frogbroth
(Post 15814293)
(Post 15814293)
I drilled a hole on the side of my battery tray to feed the balance wires through and use this portable USB charger plugged into the back of my iCharger, no need to remove the battery from Tx this way:
That IR seems normal for a TX pack. The IR measuring process doesn't just measure the cells, it also measures the wiring. TX packs have pretty small wiring.
| All times are GMT -7. It is currently 02:38 PM. |
