Stepped 4-5mm Bullet Connectors >
Like Tree1Likes
  • 1 Post By Andy Koback
Old 08-01-2021, 07:32 PM
swerv512's Avatar
Trader Rating: 17 (100%+)
Default Stepped 4-5mm Bullet Connectors
I just bought my first inboard lipo 2s packs with 5mm posts and they didn't come with any adapters for balanced charging. The batteries came with 5mm bullet connectors (for the ESC), but I need to make or find some 5mm bullet with 2mm balance jack adapters to my XT60 charger. Saving myself some time and energy, I see alot of 4-5mm stepped bullet connectors on the market. Will these fit without issue in my 5mm posts? Am I better off using a true 5mm bullet connector for charging purposes?
Thank you RC community.
swerv512 is offline
Old 08-01-2021, 07:40 PM
Trader Rating: 275 (100%+)
Stepped ones are all I use and they work great.
Andy Koback is online now
Old 08-01-2021, 09:44 PM
swerv512's Avatar
Thank you. I'll start the search.
swerv512 is offline
Old 08-01-2021, 10:33 PM
TurnNBurn's Avatar
I bought some Maclan charge cables that had stepped bullet connectors a few years ago for my Protek charger (since the optional Protek cables with 5mm connectors were out of stock) and they’ve worked great for me.
TurnNBurn is offline
Old 08-01-2021, 10:44 PM
rearviewmirror's Avatar
I use them as well, sure it would be great if all batteries were the same, but I have mix of 4 and 5mm shorty packs and want them to be available in any car so I use the 4/5mm step connectors. No issues at all so far.
rearviewmirror is offline
Old 08-02-2021, 03:45 PM
Trader Rating: 18 (100%+)
Have not ever tried these. Are the snug? I do like a decent fit.
Planning on changing to a bullet with a better way to remove as well.
Juglenaut is offline
Old 08-02-2021, 06:25 PM
Most of them have the "X" split so you can open them back up if they get too loose.
foots likes this.
Old 08-05-2021, 08:09 AM
mrreet2001's Avatar
I solely use these leads to charge. Never had an issue.
https://www.amainhobbies.com/tq-wire...aetsqalmzxactz
I assume they are using these:
https://www.amainhobbies.com/tq-wire...axtswahmzxactz
mrreet2001 is offline
