How to charge........?
How do I charge a ProTek RC 2S 100C Si-Graphene + HV LiPo Stick Pack TCS Battery (7.6V/5000mAh)
basically a 2cell Lipo in 6 cell configuration. (Search the name of battery to see what I'm talking about) thanks |
Like any other 2s LiPo. Since it's "LiPo HV" you can set the end voltage higher... but there is no standard, so consult the instructions sheet that comes with the pack for max voltage numbers. I've seen numbers from 4.25 to 4.4, though seems like 4.35 is the most common today. You can also just charge it to 4.2 like a regular LiPo.
It's a 2s LiPo in the same form factor as a 6s NiCad/NiMh. That is irrelevant to charging. The point of this description is to let consumers know this pack will fit into a battery holder designed for 6s NiCads. |
What type charger you using? Max amps your charger give out? Your Batt's same Mah!!!???
| All times are GMT -7. It is currently 09:20 AM. |
