No power
I have an electric off-road arrma raider. It has been sitting for a few months and I decided to do some laps with it the other day and I discover that even after fully charging the batteries, when I switch it on the car has now power to anything, we checked the battery was putting out the correct 8 volts and that there was continuity in every other section of circuit. We just can’t figure this one out. It was running before I put it away. I’ve tried rebinding the remote aswell but that obviously doesn’t work as there is no power to the receiver. If anyone can advise me on what I should do it would be much appreciated
Edit: thanks for all your comments, much appreciated. I have not attempted the seperate receiver powering as I don’t believe this will fix anything due to the fact the ESC is not showing any lights when switched on meaning it isn’t getting any power either. I think perhaps the switch is broken or the wires from the switch to the ESC are broken as there is some wire damage, however I think this is unlikely as there is continuity? or the wires from the battery connection to ESC are broken due to the pulling on them when disconnecting? If the switch is broken could bypassing the switch work, or would this jeopardise the system. At this point I’m clutching at straws trying to hold out from buying a new ESC |
Start looking for a loose wire or a bad solder joint. Good luck.
No power to receiver? One simple debug step is unplug the speed control from the receiver and then power the receiver directly with a battery in the 6V range. 4 AAs are fine. See if you can get steering control. Occasionally the bec in the speed control will fail, outboard units are readily available.
rebind radio and receiver..
if your going to do what dave said make sure you remove center esc wire on the rx plug. thats the +
Originally Posted by the rc guy
(Post 15769765)
Originally Posted by belewis01
(Post 15769788)
Or you can do what Dave said and unplug the ESC.....
:tire:
Originally Posted by Dave H
(Post 15769747)
... power the receiver directly with a battery in the 6V range.
(Post 15769765)
| All times are GMT -7. It is currently 08:23 AM. |
