Protek Servo Wiring
I know it has to be in here somewhere, but search didn't help me.
My Protek 160TBL has all black wires with no markings. How do you tell which is the signal wire? |
Originally Posted by rcbuggy88
(Post 15734737)
I assume it uses a universal servo lead similar to JR/Hitec/Airtronics and looks like this. The picture shows that the sealed side of the connector is up and negative wire to the right when looking directly at the plastic end. If you flip this over you will see the three clips that hold each wire to the plastic bit and the negative lead will be to the left.
https://cimg2.ibsrv.net/gimg/www.rct...bf3a9f94da.gif |
Originally Posted by SteveM
(Post 15734810)
Some may not know, but this is the tool you need to make custom length signal wires for your speed controllers, receiver batteries, and servos. This tool securely locks the connector pins onto wires from 14 to 28awg without damaging the pin or wire. Remove a small section of shield from the wires, insert the connector pin into the tool, insert the wire into the pin, and squeeze the tool to crimp the pin in place. I first learned about it when I called the electricians at tidalelectricalservices.com to change all the wiring in my old house. It certainly wasn't a day's work.
Originally Posted by Silverbullet555
(Post 15734828)
It does use the generic JR plug. I wasn't sure if it is standard to identify pinouts with the clips up.
I got mine from Hanson Hobbies. I watched a video on how to do it and it worked great.
Originally Posted by HOTROD716
(Post 15913603)
Originally Posted by Andy Koback
(Post 15913620)
And how does this answer the original question?
| All times are GMT -7. It is currently 11:08 AM. |
