Budget vs High Quality radio
Is it just response time and options for adjustments that differentiate them or is there more?
Ergonomics, features, model memory, built quality, etc are the bigger sales point to me and I think drives the price more then just the radio speed.
Another thing making the difference is the used protocols. Every brand has their own protocols with error corrections and with some cheap systems they can have little bugs giving unwanted reactions. Not that you have it all the time but if you are a good driver it can be noticed by missing the Apex from time to time.
Build quality is also noticeable. Most radios are Chinese made but you open up a Hitec or Futuba radio the wires are silicon covered, the soldering is clean and the plastics and circuit boards are decent. Open up a Flysky radio and you will see cheaper, brittle wires, messy solder ect.
My lap times and consistency have always been a wash between a budget Radiolink system compared to Radiopost and KO Propo systems that I compared at the time. What was lacking on the Radiolink system was the ability to properly set the steering speed adjustment so I was forced to run a slower servo to make up for this shortcoming. Since I ran on high grip surfaces at the time this was a non issue. What I have found recently is that running on low grip conditions requires more fine tuning between brake strength and steering/throttle speed to get things right and the budget systems don't tend to perform these features as nicely as the higher quality systems.
I have tested (or owned) just about every brand on the market and currently I'm most impressed with the HITEC Lynx 4S, it performs every advertised feature flawlessly and is extremely easy to operate. There are some name brand systems which don't perform steering speed properly or are extremely difficult to make tuning adjustments where I'm almost always adjusting the steering speed as track conditions change throughout the day.
The difference will only be noticed when running on tracks. For sure maken a switch on the same day you notice it with missing the Apex but finally with faster systems you will notice how predictable and precice you can steer the corners.
I swapped from a dx5c to an mt44 and was turning in early and clipping corners I had never hit before. For me I just wanted another radio so I could leave the dx5c at home for the bashers. The mid drop wheel is
Very comfortable to me as well.
sometimes a product comes along that fits both of these, Flysky noble nb4 - dont be dumb - buy one !
You can absolutely have all three. It just takes effort on your part to sort through what's being offered and find it.
Fanboys........
Why is Sanwa so overhyped and Futaba taken down by the same persons? (the same war as many Apple fanboys make about Android)
I can not tell about the Noble but I do hear good stuff, it seems to support higher framerates up to 333Hz so that is a plus! But yes, Frysky has a name with cheap and decent working transmitters but also known to have some issues.......
I have a habit of purchasing used gear. Especially when comes to radios. But this habit also allows me to have a taste in Ex1 , m12 for the price of a mid range radio. All these purchase taught me.one thing: im not a fast enough driver to notice the latency difference. But i can tell the difference between ergonomics and how the menu is set up. To me, these factors matters more than the pure latency time. Please notice that some resoonse time (mode) can only be activated when you are running your radio with servo or esc that supoorts the mode.
The important thing is, as long as you passed the mid level line up from a manufacturer. The resoonse time should be very similar within the same brand. High end gear will have extra adjustment options but you may or may not use it. And if not using it, the money you spent is just wasted.
As for the brands... Well, the two things i can say is, KO won't be your "bang for your buck" option. As long as it insisting on not supporting old protocols on its new radio, it stay as it is. Flysky's NB4 on the other hand, is a really good radio for the money you paid. Affordable receiver, fast left to right hand change ,colored touch screen, long battery life and decent latency . If you want a brand new radio rather than a used high end gear for under 200, NB4 should really be considered.
How would you guys judge an older top end name brand model to the current Budget systems?
m11 2.4 vs radio link rc4gs?
ooh... or the M11 2.4 compared to the MT-44 or 4PM?
(I'm running the same radio)
I have the Futaba T4GRS and the T7XC
The T4GRS is as a midrange transmitter no bad transmitter but the feeling is more plastic. The menu is clear but an ugly screen, I even prefer the screen of my okder T3VCS. The transmitter feels light an in my sense too light. From that moment comming from a thick and heavy T3VCS I still need to get used to it.
The T7XC is as a top range transmitter very expensive but from a whole other planet. It feels better in the hands. It is more solid and has some weight. The color touch screen is an eye catcher and has an easy menu. The only disadvantage is that with the original NiMh battery it is out of balance.
Although the 7XC has the super fast SR mode, I do not like the high prices of the SR servo's with normal average specs so I use the SR mode set to normal digital servo's which is basically the T-FHSS mode with Telemetry switched off.
