-   -   How to check battery voltage (https://www.rctech.net/forum/radio-electronics/1075458-how-check-battery-voltage.html)
RLB71 11-08-2020 07:14 AM
Hey guys quick question? I'm looking for a way to check how good the voltage is on my 1s packs through out a discharge. What is my best option other than a t35 ? Thanks
KE4PJO 11-09-2020 08:21 AM
If you're talking about discharging on the bench a DVM is your best option...
mrreet2001 11-09-2020 09:07 AM
You should be able to wire in just about any of these:
https://www.amainhobbies.com/search?s=battery+checker
dave-man 11-16-2020 07:22 AM
You could use one of these? It comes with software so you can view the discharge curve on a computer.
the rc guy 11-16-2020 08:12 AM
https://www.amazon.com/SKYRC-BD250-B.../dp/B087NFJN67
Nope Dave read the limits..
Voltage Range: 5.40-35.00V Low
id use a volt meter.. and theres some cells checkers and buzzer that will work if wired thru a balance plug. it will check 1 cell voltage range
purplegrape 12-05-2020 12:05 PM
I use this one. Available through most places or eBay for $10. Just plug in the bottom pins into the balancing plug of the battery.
https://www.amainhobbies.com/team-in...c23022/p148649
It will show the voltage of each cell and then ALL.
works great.
checks voltage only, does not discharge or any other function.
Roelof 12-05-2020 01:27 PM
works great.
But it does not work with 1S batteries as what was asked in the start post.....
A simple voltmeter/multi meter is the best. choice and a multimeter is always handy to have.
purplegrape 12-06-2020 04:19 AM
didn't see that, thank you
AlexLTDLX 12-12-2020 08:37 AM
You can also get super-small, self-powered voltmeters. Poke around on ebay. Put a small momentary switch in line and you can check it whenever.
